Tick() + changing FOV value
Postby Andrievskaya Veronika » Sun Nov 04, 07 8:09 am
Explain me please, how to use Tick(). For example i want to slowly increase Fov from 55 to 75, how i can do this using Tick() ??
Postby Alex » Sun Nov 04, 07 9:52 am
I guess you've already used Timer() in your script? As I would recommend using Timer().
Tick() gets called 20x per second or some, the client/host can actually change this. (I think)
If anyone can confirm this? As I'm not 100% sure. And if they could tell me what variable is used to modify this --> Then I can code something that something gets executed every second.
Postby Dae » Sun Nov 04, 07 10:29 am
Isn't tick() called every frame? I've read that somewhere on beyondunreal Wiki, and it seems a little bit strange for me, because if that was truth, different players would have different amount of ticks (I have 60 frames per second, some people have 100+, some play on 20-30).
Postby Andrievskaya Veronika » Sun Nov 04, 07 10:35 am
I not used nor timer nor tick() yet. I don't have idea how to use them in my case (i want to decrease fov from 75 to 56 slowly)
Postby Alex » Sun Nov 04, 07 10:38 am
Ok, can you tell me how to change the FOV? As I didn't use it for a loooong time.
Postby Dae » Sun Nov 04, 07 10:44 am
player.consolecommand('setfov 56');
fov 56 would work as well I think
Postby Alex » Sun Nov 04, 07 10:57 am
var DeusExPlayer Player;
function PostBeginPlay()
  Super.PostBeginPlay();
  SetTimer(1.0, False); // Call Timer in 1 second, do not repeat.
function Timer()
  if(Player.DefaultFOV > 56)
    Player.DefaultFOV      = Player.DefaultFOV-1.0;
    Player.DefaultFOV      = FClamp(Player.DefaultFOV, 1, 170);
    Player.DesiredFOV      = Player.DefaultFOV;
    if(Player.DesiredFOV > 56)
      SetTimer(1.0, False); // We have to run Timer again.
Should work... I think. Decreases FOV with 1 every 1 second. You can of course changes these values. I wouldn't change the FOV, I would change the time, so change SetTimer(1.0, False); into SetTimer(your value, False);
Postby Andrievskaya Veronika » Sun Nov 04, 07 11:01 am
... i did something, but it does not works :o
The code is located in my own PlayerClass
exec function AZoomIn()
local DeusExWeapon W;
   if ( (DeusExWeapon(inHand).bHasScope) && (DeusExPlayer(GetPlayerPawn()).IsInState('Dying') ))
      ClientMessage("Вы не можете использовать функцию приближения вида если у вас в руках оружие с прицелом :)");
      Return;
   else
//      SetDesiredFov(56);
   SetTimer(0.01, true);
   GoToState('ZoomInA');
exec function AZoomRelease()
      SetDesiredFov(75);
state ZommInA
      function Timer()
         DesiredFov=(DesiredFov - 0.5);
         log("changing fov...");
            If (DesiredFov >= 56)
                  SetTimer(0, false);
// in user.ini...
Enter=AzoomIn | onrelease AZoomRelease
In log i see that State not found, and function AZoomIn accessed None
And game freezes, when i using that function.
Edit:
Alex posted faster :)
Last edited by Andrievskaya Veronika on Sun Nov 04, 07 11:03 am, edited 1 time in total.
Postby Alex » Sun Nov 04, 07 11:08 am
function MultiplayerTick(float DeltaTime)
  local float newFOV;
  Super.MultiplayerTick(DeltaTime);
  if(DefaultFOV > 56)
    newFOV      = DefaultFOV - (1.0 * DeltaTime);
    DefaultFOV      = FClamp(newFOV, 1, 170);
    DesiredFOV      = newFOV;
What I posted will not be useable. Timer() is already used in DeusExPlayer.uc
Try using what I posted above.
Postby Andrievskaya Veronika » Sat Nov 24, 07 4:07 am
I found a "wrapper" for Tick() here:
http://www.dxediting.com/forums/showthread.php?t=2741
Users browsing this forum: No registered users and 15 guests
