my map got something strange..
Postby ~DJ~ » Fri Nov 23, 07 7:38 pm
i was making a map... then i made some stairs. Then i tested the map.. there was something i cannot see it was invicible. but i cant go up the stairs.. i see in 2d views that i did something wrong or what.. nothing was there.. so now there is a problem in my map. can it be fixed? anyway's of fixing it? *sorry i won't upload the map because anyone will copy it so i will not..* :?
Postby Allan » Fri Nov 23, 07 7:42 pm
Was there a box around the area you couldn't go into? Like when you float the crosshairs over an ornament?
Postby ~DJ~ » Fri Nov 23, 07 9:09 pm
no brush was there in 2d views nothing was there... its just i cant go thru it.. i can see the path but i cant go thru it :S
Postby Legion » Fri Nov 23, 07 9:57 pm
Sounds like a bug.. You can select all the brushes in the map at once, and then try moving the map to see if that helps any.
Legion
Postby Allan » Fri Nov 23, 07 11:08 pm
[DX-ST]DJ wrote:no brush was there in 2d views nothing was there... its just i cant go thru it.. i can see the path but i cant go thru it :S
Nonono... I mean an info box in-game. Like when you pick something up, it has the thing with something like 'Assault Rifle' on it.
Postby ~SaSQuAtCH~ » Sat Nov 24, 07 12:44 pm
The error sounds familiar from Josh's old RPG Cantinaaa. He could fix it but I don't know how.
Postby ~SyStEm~ » Fri Dec 14, 07 6:10 pm
i got dat i had to delete that part.
¤թí§§ ƒÄ©€¤
....(^_^)....
._/...._..
Win.
~SyStEm~
