Help Please
Help Please
Postby ~[EL]~[~ßïgÐàwg~] » Sat Dec 01, 07 12:31 am
Looking for files & info on installing (TKing Auto Ban mutator )
Also would like to find mutator for ingame message scrolling at the top of the screen.
also I instaled current revison of nepthys and when i start the mutator i get a gpf when i go to host a server?
Elites & Legends Forum
http://www.ElitesLegends.com
~[EL]~[~ßïgÐàwg~]
Postby Dae » Sat Dec 01, 07 9:38 am
~[EL]~[~ßïgÐàwg~] wrote:Looking for files & info on installing (TKing Auto Ban mutator )
click here
~[EL]~[~ßïgÐàwg~] wrote:when i start the mutator i get a gpf when i go to host a server?
what mutator?
Postby Dex » Sat Dec 01, 07 10:19 am
click here
what mutator?
he probably means the "Nephthys Client" or something from the Mutator list in MTL152b1.
Postby Zora » Sat Dec 01, 07 11:24 am
For Nephthys, just run the installer. DO DONT add it as mutator, since it isn't. If you already did, remove it. Examine the log to determine the reason why Nephthys don't want to run with your config.
Zora
Zora
Nephthys developer
Postby ~[EL]~[~ßïgÐàwg~] » Sat Dec 01, 07 1:06 pm
click here
what mutator?
Currently running dxmtl1.52b will be adding minimtl110
lol sry its Nephthys & antitk 110 both causing my server to gpf wierd ?
which ever one i click yes to now will cause that gpf ?
Examine what log ?
Also would like to find mutator for ingame message scrolling at the top of the screen for my server.
Last edited by ~[EL]~[~ßïgÐàwg~] on Sat Dec 01, 07 1:48 pm, edited 6 times in total.
~[EL]~[~ßïgÐàwg~]
Postby ~[EL]~[~ßïgÐàwg~] » Sat Dec 01, 07 1:55 pm
DXMTL: Mutators mPack1.ModifyPlayerSettings,MMAntiTK110.AntiTKMutator
DXMTL: Add mutator mPack1.ModifyPlayerSettings
DXMTL: Add mutator MMAntiTK110.AntiTKMutator
Critical: appError called:
Critical: AntiTKMutator DXMP_Area51Bunker.AntiTKMutator1 (Function Engine.Mutator.AlwaysKeep:0000) Infinite script recursion (250 calls) detected
Critical: Windows GetLastError: The operation completed successfully. (0)
Critical: FFrame::Serialize
Critical: UObject::ProcessEvent
Critical: (LevelInfo DXMP_Area51Bunker.LevelInfo0, Function Engine.LevelInfo.PreBeginPlay)
Critical: BeginPlay
Critical: UGameEngine::LoadMap
Critical: LoadURL
Critical: UGameEngine::Browse
Critical: UGameEngine::Init
Critical: XGameEngineExt::Init
Critical: DDeusExGameEngine::Init
Critical: InitEngine
Exit: Exiting.
Uninitialized: Log file closed, 11/14/02 07:54:10
~[EL]~[~ßïgÐàwg~]
Postby Dae » Sat Dec 01, 07 2:16 pm
Postby ~[EL]~[~ßïgÐàwg~] » Sat Dec 01, 07 4:08 pm
Thnx Dae you been really helpful one more question
Does anyone have the auto mesage scroll i seen the manual one were you have to sign in as admin then bind a message but im looking for one i dont have to login or bind to a key, or even be in the server for it to work.
~[EL]~[~ßïgÐàwg~]
Postby Zora » Sat Dec 01, 07 7:15 pm
~[EL]~[~ßïgÐàwg~] wrote:lol sry its Nephthys & antitk 110 both causing my server to gpf wierd ?
Nephthys doesn't crash your server.
Nephthys mainly is a server side security mod. Admins, who install Nephthys, expect a higher security and a better stability of their server. If you install/configure it wrongly, you may get a decrease in security and/or less stability. Nephthys tries to detect wrong setups like these and on positive results terminates the server intentionally to prevent admins from running a vulnerable server (this is not a crash, although the server exits without your interaction, just as if it crashed). The server's Unreal.log file will contain a detailed description why Nephthys terminated the server.
That's why I wanted you to look into the log file. Nvm though, since you fixed your problem already. ;-)
Zora
Zora
Nephthys developer
Postby ~[EL]~[~ßïgÐàwg~] » Sat Dec 01, 07 8:18 pm
lol I ddint change nothing it just started to work
but the anti tk still is gpfing the server on startup as you can see in the log above.
~[EL]~[~ßïgÐàwg~]
Postby Dae » Sat Dec 01, 07 8:56 pm
You should de-activate it in the mutators window if its there.
Postby Alex » Sat Dec 01, 07 8:56 pm
How do you start the server? You start up Deus Ex, then go to Internet Game and then press "Host a game"? If so, do NOT select MMAntiTK110 out of the DXMTL Mutator List ;)
Postby ~[EL]~[~ßïgÐàwg~] » Sun Dec 02, 07 2:57 pm
thnx zora dae alex I have it all working now thanks to you guys.
Last thing i want to do is find a auto message scrolling text I have the manual one but if im not in the server what good is it.
~[EL]~[~ßïgÐàwg~]
Users browsing this forum: No registered users and 15 guests
