Slomo... speed problem
Postby Dex » Fri Dec 07, 07 4:07 pm
hey guys, i run winXP, it's not vista, so you should know before thinking something that it's uncompatible
Ok, here I go:
When I run Deus Ex normally, the title screen opens and my FPS is (i seen it with fraps) at 550-1000. i mean, wtf??
when I start up my map in UnrealEd, and go to Test Map, the speed is 450-600 FPS. I think this has nothing to do with slomo, -- I said I THINK it has nothing to do, not that I know
Postby Dex » Fri Dec 07, 07 4:14 pm
Here are a few pics of what i mean:
Postby Alex » Fri Dec 07, 07 4:30 pm
Go into Deus Ex, Press T, delete Say, type Stat FPS.
Then make a screenshot of that (WITHOUT FRAPS, Just use 'sshot', or print screen)
Postby Dex » Fri Dec 07, 07 10:02 pm
Stat FPS done, here's the screenshot.
Postby ~SyStEm~ » Fri Dec 07, 07 10:05 pm
thats alot of fps i get 60 ><
¤թí§§ ƒÄ©€¤
....(^_^)....
._/...._..
Win.
~SyStEm~
Postby VodunLoas » Fri Dec 07, 07 10:31 pm
Weird because Deus Ex supposed to lock you at 60fps and not any higher.
Postby ~[R2K]D-BLOCK~ » Fri Dec 07, 07 10:59 pm
Woah thats alot of fps. :shock: Yeah mines lock me at 60 but, some has higher fps or lower fps. :?
!!!!!Come Visit [RTK] CLAN Forums Click Here
~[R2K]D-BLOCK~
Postby Eçheløn » Fri Dec 07, 07 11:51 pm
How fast is it when you're playing ?
Eçheløn
Postby Professor Layton » Sat Dec 08, 07 11:38 am
I don't see the problem here, unless you call high fps a problem...
Edit: Actually, too high fps might make the rendering a bit unstable, is that your problem?
Last edited by Professor Layton on Sat Dec 08, 07 11:41 am, edited 1 time in total.
Postby Dex » Sat Dec 08, 07 1:55 pm
My DeusEx.ini and User.ini and DeusEx.log
I have reinstalled Windows XP (using Repair Windows procedure) and deleted Deus Ex, and then reinstalled it.
Also, I have two DeusEx folders, one for playing & hosting other one for editing.
I noticed the big FPS at the editing one, where I would run "Test Map" in the SDK. It would be faster than UT set on max speed :?
When I am mentioning UT, I installed it, and then when I runned Deus Ex, joined a server, i got sounds of paper getting ripped, no sound when weapons shooting and things like that ( the sound is something like when i recieve an IM in Xfire, which I got running prior to DX, but when I would hear the sound I wouldn't get an IM, after i reinstalled WinXP and Deus Ex, i haven't been receiving no-sound when shooting, but i still got that paper-ripping sound rarely. )
When I am playing in MP i get fps of 60-150 and SP i get fps of 60-170, plus when I die i get 320 in SP.
And HIGH FPS here is a problem, the Deus Ex logo appears while I still hear the sliding Eidos logo part of the music.
For rendering I use the newest DX drivers.
Any help?
DeusEx.ini
My DeusEx.ini
(12.16 KiB) Downloaded 252 times
User.ini
My User.ini
(12.24 KiB) Downloaded 212 times
DeusEx.log
A log just after I runned DX.
(6.71 KiB) Downloaded 240 times
Postby Dae » Sat Dec 08, 07 1:56 pm
DeusEx.ini
(12.16 KiB) Downloaded 266 times
Postby Dex » Sat Dec 08, 07 2:09 pm
how the heck did my frameratelimit get to 0????
Thanks, Dae
anywayz, you didn't edit anything else, did you?
Postby Dae » Sun Dec 09, 07 1:46 pm
[B2S]deXtrUktOR wrote:anywayz, you didn't edit anything else, did you?
nope
Postby Siva » Sun Dec 09, 07 2:23 pm
Except all his RUSSIAN GLOBALIST DOMINATION LAUNCH CODES.
