my server goes to lan
Postby -[V]-dark-knight » Thu Jan 10, 08 11:42 am
i look at the topic "i cant see my server on the inter list" it doesn't help my server still goes to lan
-[V]-dark-knight
Postby Professor Layton » Thu Jan 10, 08 12:41 pm
Ask someone else to check if your server is online, a lot of people only see their own server in LAN
Postby Dae » Thu Jan 10, 08 1:05 pm
-[V]-dark-knight wrote:it doesn't help my server still goes to lan
If its on the same computer — you will always see it in the LAN games list, regardless to availability from the internet.
Postby [FTF]Freedom » Thu Jan 10, 08 4:25 pm
Make sure your ports are open/forwarded. As dae says it will always show in Lan games, but if it shows in internet games too then u've got no problem.
[FTF]Freedom
Postby -[V]-dark-knight » Thu Jan 10, 08 6:18 pm
hmm i will try out with my laptop
-[V]-dark-knight
Postby Bear » Thu Jan 10, 08 7:36 pm
Rofl, Get Batch to help you out with it, if you dont want him to go to [url]192.168.0.1[/url] or whatever your router IP is, then open ports 27900, 8777, 7790, 7791, 7792 and 7730, 7730 will allow you to see it in the internet list, if your router does not have routeback, if your router has not get the latest firmware, then you need to update it, and then open the ports.
Postby -[V]-dark-knight » Fri Jan 11, 08 1:01 pm
[FTF]Freedom wrote:Make sure your ports are open/forwarded. As dae says it will always show in Lan games, but if it shows in internet games too then u've got no problem.
it only shows in lan
-[V]-dark-knight
Postby Dae » Fri Jan 11, 08 3:39 pm
How did you forward the ports?
Postby Kaiden » Fri Jan 11, 08 7:04 pm
http://www.dxalpha.co.uk/kb/hosting/opening-ports
Read that ^^
You have a router correct? Go to your Default Gateway to get to your router's set-up, open the ports:
7790, 7791, 7792, 8777, 27900
In TCP + UDP. Restart your router and get someone ELSE to look for it in list. looking for it on a laptop in your own home won't work, as it is within a LAN (Local Area Network).
Also are you running a firewall? What's the name? And is Deus Ex allowed through it?
