i know i ask to much... Multiskins Problem >_>
Postby ~DJ~ » Thu Feb 14, 08 2:48 am
Ok.. i was testing Multiskins etc. i wanted to know how to make some cloths like FLClothsv3.. so i opened WOTGreatExporter and saw the code and made one. and when i made one and everything. i was trying to make a package. but it wont work. UCCMake shows some error. please help see the error in picture.
PS: i know you wont understand.. so i want this mod privatly. i'll PM the UC and the UTX Files to the guy who can help me..
Postby Batchy » Thu Feb 14, 08 2:55 am
Make a folder called Textures outside of classes folder and put your files in there
Batchy
Postby ~DJ~ » Thu Feb 14, 08 3:43 am
Oh! Thanks! :D
EDIT:- Dint worked :(.. which files to put? .bmp one or the UTX file i created? :?
Postby Batchy » Thu Feb 14, 08 3:47 am
Send me the files over msn
Batchy
Postby ~DJ~ » Thu Feb 14, 08 3:48 am
. Ok. >_>
umm you know.. dont copy them :P
Postby Batchy » Thu Feb 14, 08 3:48 am
Rofl.. I dont need a mod that changes skin :roll:
Batchy
Postby ~DJ~ » Thu Feb 14, 08 4:34 am
ok batch told me how to Import Textures.
but there is a problem.. the files should be .BMP or .PCX? :?
Postby clyzm » Thu Feb 14, 08 4:44 am
Either one.
Postby ~DJ~ » Thu Feb 14, 08 4:53 am
it just gives the error Again... Help someone :?
Postby Andrievskaya Veronika » Thu Feb 14, 08 5:20 am
What kind of error ? :)
Postby ~DJ~ » Thu Feb 14, 08 5:23 am
same as the above picture. :?
Postby Andrievskaya Veronika » Thu Feb 14, 08 9:25 am
Check line # 21 of GoldenDenton.uc. What there?
You importing texture into package, or you want to use an existing one (UTX)?
edit:
Get Bright to convert your textures into 256-color. This is required, otherwise you will not able to import a texture. Also check texture dimensions :)
You'll need WinRAR to unpack the archive.
Last edited by Andrievskaya Veronika on Thu Feb 14, 08 9:32 am, edited 2 times in total.
Postby ~DJ~ » Mon Feb 18, 08 1:47 pm
there are converted.... ok enough i need a real help here you go i am uploading it here... PS. everyone knows no copying please :P
check it with uccmake... and tell me whats the problem :S
STGoldMod.zip
(314.42 KiB) Downloaded 431 times
Postby Andrievskaya Veronika » Mon Feb 18, 08 2:06 pm
See:
           Player.MultiSkins[0]=Texture'skins.GoldenDentonTe0';
Replace it with
           Player.MultiSkins[0]=Texture'GoldenDentonTe0';
Same with others.
Postby ~DJ~ » Tue Feb 19, 08 4:20 am
it says g p f :?
Postby Dae » Tue Feb 19, 08 11:09 am
Where and what exactly does it say?
Postby ~DJ~ » Tue Feb 19, 08 11:13 pm
Sorry dint mention the whole error. it happens when i "Ucc Make" to make the package :S. here is the picture.
Postby Dae » Tue Feb 19, 08 11:56 pm
Oh well, you forgot to convert your textures to 8bit format.
The easiest would be to convert to .GIF, and then back to .PCX.
Like it says here.
Postby ~DJ~ » Wed Feb 20, 08 3:08 am
Ok but is it important to import 8bit PCX files?
Postby Andrievskaya Veronika » Wed Feb 20, 08 4:52 am
¥~ÐJ~¥ wrote:Ok but is it important to import 8bit PCX files?
Andrievskaya Veronika wrote:Get Bright to convert your textures into 256-color (i.e. 8-bit). This is required, otherwise you will not able to import a texture.
You can import full-color images (24-bit ?), but you'll need UED3 to do that. Also this will require Enhanced OpenGL (otherwise Deus Ex wil crash).
I converted your textures.
Corrected.zip
(107.02 KiB) Downloaded 546 times
Postby clyzm » Wed Feb 20, 08 5:52 am
(24-bit ?)
I think it was 32-bit or 64-bit.
Postby ~DJ~ » Wed Feb 20, 08 5:54 am
Thanks! it worked.. but how :? i tried everything! Well Thanks x 99999999999999999999999999999999 :D
Also the texture "GoldenDentonTex0" is fine but not fine in DX. see the picture .. well the mod is completed i just used JCDentontex6 :D
(37.77 KiB) Downloaded 95 times
Postby Andrievskaya Veronika » Wed Feb 20, 08 8:45 am
¥~ÐJ~¥
Oh, seems to be i forgot to convert one of textures :o
Try this one.
GoldenDentonTex0.zip
(10.46 KiB) Downloaded 705 times
Postby ~DJ~ » Wed Feb 20, 08 9:26 am
oh well np :P
i dont need it now but still thanks and here is the mod
//Pictures
Download STGoldmod.zip
.. my 2nd mod xD
Postby Kaiden » Wed Feb 20, 08 9:36 am
Looks cool I'll try it out. :D
Postby ~DJ~ » Wed Feb 20, 08 9:47 am
thanks :D
Postby ~DJ~ » Wed Feb 20, 08 2:53 pm
o lol i dint add one texture file. wait i'll fix it :S sorry guys :S
STHandguntex.zip this is the texture file. if you dont add it it will not run.. >_<
Postby ~DJ~ » Fri Mar 14, 08 5:30 am
Andrievskaya Veronika wrote:Check line # 21 of GoldenDenton.uc. What there?
edit:
I Am Making V2
When i click the "Bright.exe" it just blink and closes :/ (its kinda batch file code gone wrong.. i cant even see the error i took a screenie but its too fast missed it :/)how to Make it 8bit :/.. wait i'll try Daedalus Way.
Its not a double post cause i cant edit the previous one >_<
Postby Andrievskaya Veronika » Fri Mar 14, 08 5:48 am
¥~ÐJ~¥, run CMD.exe , because Bright is a console program :)
Type bright /? to get help about command line switches
See screenShot.
The Daydream
Last edited by Andrievskaya Veronika on Fri Mar 14, 08 5:54 am, edited 1 time in total.
Postby ~DJ~ » Sun Mar 16, 08 8:15 am
heh i knew it :roll:
joking thanks alot :)
i made a shortcut for it here u go..
some ppls like dae dont like to open batch file so left click it and click edit. to see the code. and i did not made any dangerous batch file ;)
(remember to paste it where you extract the Bright.exe and the image together)
Shortcut.zip
(344 Bytes) Downloaded 515 times
Users browsing this forum: No registered users and 14 guests
