I have just released my latest map called DXMP_Command_Post. I haven't released anything for DXMP for about 6 years, so be gentle
The map is based around a military command post. There are three main fighting areas: (1) The base compound, (2) Helipad area and (3) Barracks area.
I have implemented an airstrike system (code based) in the map which allows players to call for an airstrike at different times during the match. To initiate the airstrike you need a "launch authorisation code" which is available from a datacube located somewhere in the map. Once you have this code you must enter it into the launch console when it becomes accessible (3 minutes from start of match and 3 minutes after the previous airstrike). The code is random and changes for every airstrike and every match so there's no use trying to remember it once an airstrike has been called
You can download it from my website http://www.facedesigns.co.uk/ in the files section, or just grab it here: http://www.disclosuremod.co.uk/maps/DXMP_Command_Post.zip.
Command Post - Map Overview 1
Command Post - Map Overview 2
Command Post - Flight Control Deck
Command Post - Launch Console
Command Post - Bunker (Airstrike safety!!)
Hope you enjoy!
Face
