DeusEx style door problem
Postby NightRaver » Wed Sep 23, 09 5:50 pm
The problem is that sometimes one side of the door is black even when that room is lighted and the door should be seen. But when i shine my light on it ingame it does show the texture of the door.
Any idea whats wrong?
Raving through life!
NightRaver
Postby ~SaSQuAtCH~ » Wed Sep 23, 09 5:51 pm
You probably skipped intersecting the brush before making it a mover.
Postby NightRaver » Wed Sep 23, 09 5:52 pm
No i didnt skip it.
NightRaver
Postby ~SaSQuAtCH~ » Wed Sep 23, 09 5:58 pm
Then try adding a light close to the mover and then intersect. See if it's still dark.
Postby Snakey » Wed Sep 23, 09 6:10 pm
Go to the default properties, under the Mover subsection, set "DynamicLightMover" to true.
Postby NightRaver » Thu Sep 24, 09 10:18 pm
Snakey wrote:Go to the default properties, under the Mover subsection, set "DynamicLightMover" to true.
Yerr done that, thanks anyway problem fixed.
NightRaver
Postby Legion » Fri Sep 25, 09 4:36 am
Probably should state how you fixed it in the event somebody else has the issue they will be able to use the same steps.. just a thought.
Legion
Postby NightRaver » Fri Sep 25, 09 2:53 pm
set "DynamicLightMover" to true. :P
NightRaver
