2nd Hard Drive
2nd Hard Drive
Postby ~s0ap~ » Wed Jul 28, 10 3:40 am
From that same computer, I removed a Seagate Barracuda 7200.7 120gb. I want to put this in my current computer, and I could use instructions...
~s0ap~
Postby Allan » Wed Jul 28, 10 3:58 am
- Is the hard-drive formatted already?
- Does the hard drive use IDE/ATA (something like 40 small pins, and 4 big pins) or SATA (Large slot for power, smaller slot right next to it for data)?
Postby Alex » Wed Jul 28, 10 8:58 am
To make Allan's second question a bit more understandable:
Does it look like the upper or lower harddrive?
Postby ~s0ap~ » Wed Jul 28, 10 6:36 pm
I may only be 12, but I understand his question. I have the kind with like 40 pins, 4 big pins, then theres 4 small pins with a black piece of plastic. It should be formatted because it is from my brother's work
~s0ap~
Postby Allan » Wed Jul 28, 10 7:10 pm
Well, that black pin is the drive setting jumper. Usually it's on Cable Select.
You need to put the 40-Pin IDE cable in (It should only go in one way, but if not: red wire faces towards the 4 pin power plug). Then, put in the power plug.
If you're running XP, go to your start menu, and type "compmgmt.msc". In Computer Management, choose "Disk Management".
Find your drive, and choose "Initialize Disk" (or something like).
After that, it should be simplish. Sorry, I don't know how to do it in anything other than XP. :(
Postby ~s0ap~ » Wed Jul 28, 10 8:15 pm
Will do, by the way I got XP Home anyways....
~s0ap~
Postby Aidan » Wed Jul 28, 10 8:50 pm
Well.. as long as you arn't runnign 98, you should be fine ;)
Postby Wasted. » Wed Jul 28, 10 10:53 pm
good input
Wasted.
Postby Aidan » Thu Jul 29, 10 3:39 am
That's what I thought. Especially the way I spelled running...
I think I'll just leave it like that :/
Postby James » Thu Jul 29, 10 7:25 am
Aiden stop replying to all threads with no real input for the sake of posting.
Postby Aidan » Thu Jul 29, 10 5:35 pm
James wrote:no real input for the sake of posting.
You got me.
Postby ~s0ap~ » Thu Jul 29, 10 8:16 pm
Okay, I got it working, thanks.
~s0ap~
Users browsing this forum: No registered users and 15 guests
