Mass Effect 2
Postby clyzm » Tue Jan 11, 11 8:36 am
DEREK
http://hardforum.com/showthread.php?t=1490089
still no proper support but it's basically what i said
seems to only work in portrait mode, i have landscape : o
i just tried it now and everything's SUPERZOOMED like fuck, but it makes convos a lot more interesting when garrus's face is spread across 2 1/2 monitors
Postby James » Tue Jan 11, 11 8:40 am
klizzem wrote:garrus's face is spread across 2 1/2 monitors
valentine's day came early
Postby James » Thu Feb 09, 12 4:11 pm
http://www.masseffectsaves.com/xbox.php
Let's you convert ME2 saves from PC/360 to 360/PC.
Postby ynnaD » Thu Feb 09, 12 4:18 pm
Great find.
Thinking of replaying as woman shep at the moment
Postby James » Sun Feb 19, 12 6:17 pm
Dumping these face codes so I don't forget:
Freddie Mercury:
541.IGI.K9E.C25.FIL.19W.U8H.6NL.K75.4R2.C57.6
RUGGED AS FUCK:
523.WTG.H8U.13I.SCL.G7W.M8L.69W.DH8.622.837.6
Postby James » Sun Feb 26, 12 11:03 pm
Dumping for reference
Postby James » Mon Feb 27, 12 10:08 am
You may not notice but Mass Effect 2 was badly optimised and you can tell so when you modify it. Patch the RAM/system memory allocation of the MassEffect2.exe.
Also each time you launch remove all core affinity in the processes to 1 core, save, put all cores back on, save.
Postby ynnaD » Fri Mar 02, 12 10:30 am
So whose all for getting ME3 next week then?
I won't get it straight off, i want to replay ME2 first.
Postby James » Fri Mar 02, 12 10:55 am
Not me and I feel sorry for anyone who pays for it.
Postby James » Sat Mar 03, 12 2:15 pm
I'm using the alternative appearence pack at the moment, it makes Miranda and Garrus look much better for combat. I mean having a cat suit and a cool broken piece of armour is sorta cool but... y'know.
Postby James » Mon Mar 05, 12 7:40 am
Did you know if you do Zaeed's loyalty mission after the suicide mission and choose the hostages route, you have the option to blow Zaeed's brains out? Did I mention this is the paragon path?
Postby ynnaD » Mon Mar 05, 12 1:11 pm
James wrote:Did you know if you do Zaeed's loyalty mission after the suicide mission and choose the hostages route, you have the option to blow Zaeed's brains out? Did I mention this is the paragon path?
His was the only mission i failed to get loyalty on, what a dick.
AND HE WAS DLC TOO FFFFFFFFFF
Postby James » Mon Mar 05, 12 1:14 pm
He's loyal if you hold a gun to his head in hostage situation, you need paragon points for that however.
