Augs Mutator
Augs Mutator
Postby Trailmix » Mon May 09, 05 12:20 am
I had an idea of twisting Deus Ex augs. A mutator that allows augs to run forever. I asked TheSheep to code it and he did. It's in the testing period now cause it keeps making my DX GPF. So what do you guys think of this?
It'd be a good experience for new aug players to get the feel of augs and practice with them. When they're good, they move on to bio-draining.
Trailmix
Postby Bobo. » Mon May 09, 05 12:48 am
Ah yes....TheSheep my old mapping/coding pro :D
Bobo.
Postby Bob » Mon May 09, 05 11:56 am
TheSheep used to be a DF member, right?
And yeh, tell us more trail, what are the whole effects of this mutator?
Postby Bobo. » Mon May 09, 05 12:18 pm
Yeah,Lordz and DF rofl
Bobo.
Postby kBo » Mon May 09, 05 12:32 pm
Just infinite bio I guess so the augs never run out.
kBo
Postby Dejavu » Mon May 09, 05 3:22 pm
that would a be a good idea. i just have one newbie on training and he is so happy with his speed augmentation (as long as he has bio).
Dejavu
Postby Dae » Mon May 09, 05 3:32 pm
what are you testing in it? :shock: infinite bio can be done via a couple of set commands, in mutator its the same, 3-4 lines of code, i think.
Postby Trailmix » Mon May 09, 05 3:55 pm
I'm not sure about that either. But here's the code: And the .int file should be straightforward.
class AugMutator extends Mutator;
function ModifyPlayer(Pawn Other)
local Augmentation aug;
if(Other.IsA('DeusExPlayer')) //which it should be
 for(aug=DeusExPlayer(Other).AugmentationSystem.FirstAug;
   aug!=None;aug=aug.Next)
   aug.EnergyRate=0; //no drain
   aug.bAlwaysActive=True; //always on
AugMutator.int
[Public]
Object=(Name=AugMutator.AugMutator,Class=Class,MetaClass=Engine.Mutator,Description="Aug mutator, Augmentations run constantly and don't drain energy")
Preferences=(Caption="Aug Mutator",Parent="Mutators",Class=AugMutator.AugMutator,Immediate=True)
Trailmix
Postby AlexDenton » Mon May 09, 05 7:05 pm
there you have it
AlexDenton
Postby Dae » Mon May 09, 05 7:36 pm
Trail wrote:I'm not sure about that either. But here's the code: And the .int file should be straightforward.
I'm not a specialist, but i think that the iteration here is a bit complicated. I'd make it with foreach and Augmentation class, where we can see a magnificent variable EnergyRate which should be set to 0.
In other words, mutator should "type" this command just automatically instead of admin:
admin set augmentation.energyrate 0
Postby Trailmix » Thu May 12, 05 6:45 am
TheSheep:
Fair cop on the "type this command" statement, if there was some way to bypass the issue that not every person in the server, if any, are admins. And I think "set" probably uses a foreach-style iterator. Which brings me onto my next point...
The comment on the iterator is just plain wrong. foreach is sloppy for inventory or augs because it has such a slow hit rate and takes up valuable cycles on the host machine. It cycles through every single actor in the map, does a ClassIsChildOf check, and processes each one in turn. The "aug" linked list goes through about a dozen. Woosh.
In conclusion, fair points but I stand by my code. Well, most of it
And if you were to use that admin code, Dae, wouldn't each copy of the mutator need to be custom?
Trailmix
Postby clyzm » Thu May 12, 05 7:20 pm
Augs mutator, good idea :)
Postby Alistair » Thu May 12, 05 8:00 pm
admin human energy 99999999999999999
:D
Postby Jeoh » Thu May 12, 05 8:48 pm
You'll run out that way.
Jeoh
Postby Trailmix » Thu May 12, 05 11:43 pm
And you'll have to reset it everytime which is what GG an i did at stealth training. :wink:
Trailmix
Postby clyzm » Sat May 14, 05 8:27 pm
That got annoying :S
"trail, can you reset the energy?"
