WTF2
WTF2
Postby H1tman » Wed Jun 22, 05 10:13 pm
And yet again my serve is NOT visible.... -_-
H1tman
Postby SuperMAN » Wed Jun 22, 05 10:55 pm
just burn the whole computer... thats your answer :wink:
SuperMAN
Postby moop » Thu Jun 23, 05 1:50 am
If you are behind a NAT firewall, you probably won't see your server in the main Server List, even though it's actually available. You will see it running in the LAN menu, but that's not a guarantee that it's available to everyone. You need to ask someone to test it for you, and give them your external IP address just to make sure. If you're behind NAT, you'll have your local IP (usually something like 192.168.1.1) and your external IP (varies, depending on your ISP) which you can check at http://www.whatismyip.com
Hope that helps.
moop
Postby H1tman » Thu Jun 23, 05 2:00 am
moop wrote:If you are behind a NAT firewall, you probably won't see your server in the main Server List, even though it's actually available. You will see it running in the LAN menu, but that's not a guarantee that it's available to everyone. You need to ask someone to test it for you, and give them your external IP address just to make sure. If you're behind NAT, you'll have your local IP (usually something like 192.168.1.1) and your external IP (varies, depending on your ISP) which you can check at http://www.whatismyip.com
Hope that helps.
Yeah exactly problem is i've ppened all the ports o_0...
I know i am behin NAT....
H1tman
Postby Alistair » Thu Jun 23, 05 8:11 am
whatismyip lies, you are probably behind a subnet mask, for me i hacked my friends bt 205 voyager :]
Postby ~ô¿ô~Nobody~ » Thu Jun 23, 05 11:07 am
how can one be behind a subnetmask... O_o
Users browsing this forum: No registered users and 22 guests
