Trouble with funline unlimited party 3
The forum for discussions that don't fall into any of release topics below.
Postby Alex » Sun Aug 28, 05 2:28 pm
Warning: Failed to load 'GameEffects': Can't find file for package 'GameEffects'
Warning: Failed to load 'Funline_UnlimitedParty-3': Can't find file for package 'GameEffects'
Warning: Failed to load 'Level None.MyLevel': Can't find file for package 'GameEffects'
GameEffects.utx
Place it in the Textures folder =)
(89.07 KiB) Downloaded 511 times
Postby Dae » Sun Aug 28, 05 2:34 pm
All the files are here
http://www.dxalpha.com/forum/viewtopic.php?t=4915
including GameEffects
Postby Big Daddy » Sun Aug 28, 05 4:56 pm
thanks guys, I'll send you the summary if it works or not
Postby Big Daddy » Sun Aug 28, 05 5:10 pm
I am on the edge now!!!!!!!!!!!!!!!! For some gay retarded reason every time I host it goes off straight away, why? I have had enough of this
Postby Dae » Sun Aug 28, 05 5:11 pm
Post log again :)
And most likely you added something in editpackages= or serverpackages= that doesn't exist.
Postby Alex » Sun Aug 28, 05 5:12 pm
Post your server.log again =)
Postby Gishank » Sun Aug 28, 05 5:47 pm
Tantulas klop here look i will send u a new copy of the file so plz post the Server.log again.
Postby Big Daddy » Sun Aug 28, 05 6:08 pm
hang on I did put flserversv3 in to edit and server packages, maybe that's it
Postby Big Daddy » Sun Aug 28, 05 6:20 pm
here it is
~log removed because of no relevant content~
Postby Snakey » Sun Aug 28, 05 6:21 pm
No, it's not.
It would make little difference unless you use UnrealEd alot and like to place modded weapons in your maps.
Postby Gishank » Sun Aug 28, 05 7:09 pm
soz can't find a problem soz again.
Postby Big Daddy » Sun Aug 28, 05 7:33 pm
Log: Loading: Package FLKeypad2
Log: Loading: Package GameEffects
Critical: appError called:
Critical: Ran out of virtual memory. To prevent this condition, you must free up more space on your primary hard disk.
Critical: Windows GetLastError: The parameter is incorrect. (87)
please help I am about to go mad if it doesn't work
Postby Gishank » Sun Aug 28, 05 7:47 pm
tantulas i have found the problem u need to edit but make a back up befor u do so cos' i might be wrong get a total new map first delet your old one and the effects file then download it again 8)
Postby Dae » Sun Aug 28, 05 7:47 pm
It's easy.
You ran out of disk space :)
Postby Gishank » Sun Aug 28, 05 7:50 pm
:D Hey tantulas the proplem is u ain't got enogh disk space :D
Postby Big Daddy » Sun Aug 28, 05 9:01 pm
how do I free more space?
Postby Marouku » Sun Aug 28, 05 9:02 pm
Delete.
Things.
Marouku
Postby ~ô¿ô~Nobody~ » Sun Aug 28, 05 9:04 pm
format C: :lol:
Postby Big Daddy » Sun Aug 28, 05 9:04 pm
like the mods?
Postby ~ô¿ô~Nobody~ » Sun Aug 28, 05 9:06 pm
well..
i guess there is something that you don#t need on your drive anymore..
so deinstall not used programs or games and clean your drive with the clean utility of windows
Postby Marouku » Sun Aug 28, 05 9:09 pm
Or do what I do, and delete crap in Program Files.
Marouku
Postby Dae » Sun Aug 28, 05 9:11 pm
oUtKaSt wrote:Or do what I do, and delete crap in Program Files.
The best thing to do is to uninstall programs via Control Panel (Install/Remove programs or w/e its called).
Postby ~ô¿ô~Nobody~ » Sun Aug 28, 05 9:15 pm
~[A]Nobody~ wrote:so deinstall not used programs or games and clean your drive with the clean utility of windows
*ahem*
*repeats*
Postby Dae » Sun Aug 28, 05 9:16 pm
lol, why can't i repeat? :)
one more voice is more like a provement of this statement
Postby ~ô¿ô~Nobody~ » Sun Aug 28, 05 9:17 pm
hmm if you want we can always repeat eachother again but it will end up in a biiig echo :P
not that he throws his HD out of the window at the end XD
Postby Big Daddy » Sun Aug 28, 05 10:05 pm
I have deleted 2 games will that do?
Postby Big Daddy » Sun Aug 28, 05 10:12 pm
I still don't have enough memory, why?
Postby DOGNY » Mon Aug 29, 05 12:46 am
DELETE! DELETE DELETE!
Delete the single player maps if you don't use them, That'll give you some room!
DOGZ SERVER RULEZ
[A]lpha Clan is #1
FunLine is the BEST!
Keeping DX Alive
DOGNY
Forum Dog
Postby Marouku » Mon Aug 29, 05 2:03 am
(TM)Tantalus(H(AW) wrote:I still don't have enough memory, why?
Because your max disc space is probably low as hell.
Marouku
Postby Big Daddy » Mon Aug 29, 05 7:21 am
can I put them in the recycling bin?
Return to Comments, questions, requests
