[Solved @ Snakey] Navigating in UnrealEd
Postby ~Sandro~ » Sun Oct 23, 05 2:41 pm
ok ,time for another newbie unrealed question by LordSandro:
When I build a brush for exemple a cube, how do I view it from inside then from ouside, I mean how do I change the camera position in the 3D screen, the first thing I build I view it from outside then all the other only from the ouside, what to do????? help :!: :!: :!:
~Sandro~
Re: Help me once more!!!!
Postby Dae » Sun Oct 23, 05 2:54 pm
LordSandro wrote:...how do I change the camera position in the 3D screen...
Link. Scroll down to "navigating the 3D view".
Postby ~Sandro~ » Sun Oct 23, 05 3:00 pm
thanks Dae! Hope this will be the last thing I ask you, I hope I will discover evrything else myself :lol:
~Sandro~
Postby ~Sandro~ » Sun Oct 23, 05 4:44 pm
Damn It does't work! :oops: Mayby I m doing something wrong??? I press alt and rightclick? FUCK! the only think i managed to do is separating my two cubes, now i have two same cubes and i CAN edit one from the inside the other from outside but how do I merge them HELP !!!!!!
~Sandro~
Postby Dae » Sun Oct 23, 05 5:12 pm
LordSandro wrote:Damn It does't work! :oops: Mayby I m doing something wrong??? I press alt and rightclick? fsck!
Alt and right click doesn't do anything as far as i remember.
Postby ~Sandro~ » Sun Oct 23, 05 5:14 pm
LordSandro wrote:Damn It does't work! :oops: Mayby I m doing something wrong??? I press alt and rightclick? fsck! the only think i managed to do is separating my two cubes, now i have two same cubes and i CAN edit one from the inside the other from outside but how do I merge them HELP !!!!!!
~Sandro~
Postby Dae » Sun Oct 23, 05 5:16 pm
i don't get shit
provide a screenshot
Postby ~Sandro~ » Sun Oct 23, 05 5:28 pm
no need, I got what was wrong!and I got how to see my fucking cube from the inside!! but i can do it only when my cube is outside of the FUCKING big cube (the level itself) when i put him back he is back to ouside view!
PS: I am a man of trouble :cry:
~Sandro~
Postby ~Sandro~ » Sun Oct 23, 05 5:43 pm
No i was wrong it's back. here insted of one cube, I got two! Aaaaaah ! ! !
~Sandro~
Postby Snakey » Sun Oct 23, 05 5:45 pm
By making a cube I assume you mean subtracting.
Think of the giant UnrealEd grid as a block of wood, and a huge one at that.
When you subtract, you are taking a chunk out of that wood in the size/shape you specified.
If you subtract a very large cube and try to subtract another one inside it, nothing happens, because you're just getting rid of an empty space.
To merge the cubes you have to make another subtraction, move the cubes next to each other so that the one edge from each cube are touching, and it will form a subtraction the same size as 2 cubes, like a long corridor.
Postby ~Sandro~ » Sun Oct 23, 05 5:51 pm
Ok, but that's not my problem, my problem is how do I change the view in my Fucking cube from ouside to inside, I tryded lots of things and I ended up with two similar cubes :lol: ,And i can view one from ouside the other from inside, But All i want is one damn cube than can be viewed from both side, I don't ask much :(
~Sandro~
Postby Dae » Sun Oct 23, 05 5:53 pm
Aaaah lol,
try bHollow=true OR (better) make a cube by ADD command, and inside it make a cube by SUBSTRACT command, but in this case, substracted cube should be smaller than added one. That's all.
Postby Snakey » Sun Oct 23, 05 5:56 pm
LordSandro wrote:Ok, but that's not my problem, my problem is how do I change the view in my fscking cube from ouside to inside, I tryded lots of things and I ended up with two similar cubes :lol: ,And i can view one from ouside the other from inside, But All i want is one damn cube than can be viewed from both side, I don't ask much :(
You want to view from the inside?
Just go into the cube by moving with into it in the 3d view.
Postby ~Sandro~ » Sun Oct 23, 05 6:05 pm
DAMN I AM StUPID HELP ME!
~Sandro~
Postby ~Sandro~ » Sun Oct 23, 05 6:10 pm
YES I want o view from inside, but i also want to change the textures from inside and ouside, when i move inside my cube i see only my level not the cube from the inside.
~Sandro~
Postby Snakey » Sun Oct 23, 05 6:11 pm
To do that you'd need to make a big cube, make an addition cube inside that cube and make a subtraction in the addition cube.
I use the term "cube" loosely.
Postby ~Sandro~ » Sun Oct 23, 05 6:39 pm
i got! i got it! i got it! i got i i got it thanks evryone,but how do i move my new cube now??? Do i have to select them both or just moving one will sufise?
~Sandro~
Postby Snakey » Sun Oct 23, 05 7:00 pm
If you want to move the whole thing, you need to select them both and move them
Postby ~Sandro~ » Sun Oct 23, 05 7:32 pm
thank you Snakey!thank you Dae! Hope one day i reach your mapping skill guys! thanks a lot!
Now I'll go back to my cubes..... :)
~Sandro~
