my server isnt on the server list...no router
Postby Avenger » Mon Dec 18, 06 10:58 pm
its not showin on the list can u pls help?
I will withdraw; but this intrusion shall
Now seeming sweet, convert to bitt'rest gall
|<~~Avenger~~>|
Avenger
Postby Avenger » Mon Dec 18, 06 11:10 pm
Please help me.
|<~~Avenger~~>|
Avenger
Postby Avenger » Mon Dec 18, 06 11:20 pm
sorry for d triple post
now when i how a dedicated server on the internet game
the server only comes up on the lan game
can u pls help?
thanks.
|<~~Avenger~~>|
Avenger
Postby Mastakilla » Mon Dec 18, 06 11:22 pm
Postby Avenger » Mon Dec 18, 06 11:26 pm
i DON'T have a router
|<~~Avenger~~>|
Avenger
Postby Wise Man - 2 WAIZ 4 U » Tue Dec 19, 06 12:12 am
Avenger wrote:i DON'T have a router
Seems like thou dost not have any testicles either.
Postby Avenger » Tue Dec 19, 06 12:41 am
is tht any use...no
|<~~Avenger~~>|
Avenger
Postby Siva » Tue Dec 19, 06 1:22 am
Avenger wrote:is tht any use...no
Neither is triple posting. ZING!
Postby Avenger » Tue Dec 19, 06 10:01 am
i was psoting new info about..
cab aby1 help ?
|<~~Avenger~~>|
Avenger
Postby Dae » Tue Dec 19, 06 11:14 am
Avenger wrote:i was psoting new info about..
cab aby1 help ?
Use 'edit' button, dumbass.
Do you see your server in the list of LAN games?
Postby Gishank » Tue Dec 19, 06 11:16 am
Fucking hell your spelling's a disgrace....
Just get nepthy's installed.
Postby Siva » Tue Dec 19, 06 2:11 pm
cab aby1 help ?
Dae snapped. :D
Postby Avenger » Tue Dec 19, 06 3:46 pm
yes evan when i start server in internet game
sry daedalus
didnt no dere was an edit button
|<~~Avenger~~>|
Avenger
Postby Kaiden » Tue Dec 19, 06 4:25 pm
Your server should appear in the Lan list be default....Even if your hosting an internet game. People may not be able/want to join your server, so you can't really prove it's not working.. :o
Postby Avenger » Tue Dec 19, 06 4:31 pm
ok now its this:
i cant see my server on the server list
how do i no ?-- i went to unreal server comsole nd i say this--
Say:stephan: hi
there other people can see it
can u pls help ?
|<~~Avenger~~>|
Avenger
Postby Avenger » Thu Dec 21, 06 3:20 pm
ok i,ve uninstalled slimline nd my server still isnt on the internet game server list
any help
thanks
|<~~Avenger~~>|
Avenger
Postby Kaiden » Thu Dec 21, 06 4:28 pm
§ KÃÎÐEN § wrote:Your server should appear in the Lan list be default....Even if your hosting an internet game. People may not be able/want to join your server, so you can't really prove it's not working.. :o
Postby Avenger » Thu Dec 21, 06 4:42 pm
no one can see it tho
|<~~Avenger~~>|
Avenger
Postby Avenger » Thu Dec 21, 06 10:55 pm
hey look can some one just please help me thanks
|<~~Avenger~~>|
Avenger
Postby Grayfox » Fri Dec 22, 06 5:01 am
Learn English and someone might be willing to help you.
Grayfox
Postby Avenger » Fri Dec 22, 06 10:10 am
oh yes because i was speaking german
|<~~Avenger~~>|
Avenger
Postby [Om]Angelus » Fri Dec 22, 06 10:16 am
I dont think it is a normal problem, it seems similer to my prob.
My post with probs, BLAME DEJA!!!!
But just in case, post your DeusEx ini and Server log, via attachment if possible.
Sun Tzu wrote:Know your enemy better than you know yourself.
Taken from Art Of War
The enemy approaches
Omega rises
[Om]Angelus
Postby Avenger » Fri Dec 22, 06 10:22 am
ok do you know where i can get the server.log
? thanks
|<~~Avenger~~>|
Avenger
Postby [Om]Angelus » Fri Dec 22, 06 10:27 am
it is a file in the system folder, its called DeusEx.
Just look through the files called DeusEx. The server.log file keeps track of everything going on in your server, like Mutators bieng loaded, uplinks to the master server, and all that stuff.
The first few lines of the file should look like this.
Log: Log file open, 12/22/06 06:43:19
Init: Version: 1100
Init: Command line:
Init: Base directory: C:\DeusEx\System\
Init: Character set: Unicode
Log: Bound to Engine.dll
Log: Bound to Core.dll
Log: Bound to Window.dll
Log: Cd Path: D:\
Omega rises
[Om]Angelus
Postby Avenger » Fri Dec 22, 06 10:48 am
hey here you go thanks
it says that it cant find file package converstaions but my server runs ok it just cant be seen
thanks
server.log
thats the server log
(17.42 KiB) Downloaded 267 times
|<~~Avenger~~>|
Avenger
Postby [Om]Angelus » Fri Dec 22, 06 11:57 am
I think the DeusExConText file is important for something. It must be important for the server or it would not have appeared on the server.log so many time :shock:
Try Checking your PC's RecyclingBin to see if you havnt deleted the file by mistake.
Omega rises
[Om]Angelus
Postby Dae » Fri Dec 22, 06 12:11 pm
I guess it's SlimLine's fault :(
Can you install a full Deus Ex version?
Postby [Om]Angelus » Fri Dec 22, 06 2:08 pm
I was suspecting the Slimline too, but i thought i would mention the more obviouse 'Missing File' error message first.
Omega rises
[Om]Angelus
Postby Kaiden » Fri Dec 22, 06 2:48 pm
Doesn't Imp have the CD? Go steal it off him.
Postby Professor Layton » Fri Dec 22, 06 3:33 pm
It gives the error but it doesnt make the server impossible to show up, (Ren server had it), as rosso couldnt be bothered to upload a big file due to his failing connection.. though if you hate to see the error, I could upload deusexcontext.u, which will void the warning, although I doubt these forums would allow me to upload files of that size.. I'll try it anyway.
Edit: seemed to have worked, just unzip it and put it in your deusex\system to get rid of the error.
DeusExConText.zip
(1.06 MiB) Downloaded 249 times
