[PATCH] MMUserInterface (v1.8)
Postby ~¤Hit[+]Män¤~ » Sat Mar 17, 07 1:43 am
This mod is great 8)
Asus Blitz Formula
q6600 G0 revision
2gb of kingston hyper x ram pc 6400 800mhz
hd 2600 xt 512mg x2 crossfire
silverstone psu
Dell Ultrasharp 30"
~¤Hit[+]Män¤~
Postby VodunLoas » Tue Mar 20, 07 11:05 pm
I just noticed if I host dedicated and then go into my server it immediantly shuts the server down, but it's fine if I don't use MMUI!
Postby ~¤Hit[+]Män¤~ » Wed Mar 21, 07 1:27 am
VodunLoas wrote:I just noticed if I host dedicated and then go into my server it immediantly shuts the server down, but it's fine if I don't use MMUI!
should probally post your log :wink:
Asus Blitz Formula
q6600 G0 revision
silverstone psu
Dell Ultrasharp 30"
~¤Hit[+]Män¤~
Postby VodunLoas » Wed Mar 21, 07 1:56 am
I figured out why. I had a custom script I made awhile ago, and had this set in DeusEx.ini:
[URL]
Class=VodunsHUD.MyJC
It works fine without MMUI, and it dosn't use it in my server.
But with MMUI I guess I have to change it, so I put it to:
[URL]
Class=DXMTL152b1.MTLJCDenton
Anyone get that problem, then you should now know why.
Postby Dae » Wed Mar 21, 07 11:28 am
For hosting purposes i use stand-alone DXMP version. You may just use a separate .ini (add to query/as a shortcut parameter to DeusEx.exe ?ini=mynew.ini).
Postby [FGS]ShadowRunner » Sun Apr 01, 07 10:48 pm
Brilliant work Alex and Team... I could see scrollbars and many servers!!!
After I installed version 144, I could see scroll bars and many many servers.
Today, after upgrading Firefox and Firewall I downloaded new MMU 160.
BUT now, my server list shows no scrollbars, now shows only about 6-8 servers, mostly 0-aug, FGS-Augged shows and DXMS show, but Deja's servers and Altfire are gone...
If I set bcombinemasterservers = True, I see only DXMTL.EU servers (I think.)
If I set bcombinemasterservers = False, I see exactly the same number of servers as before, only now, I can see the button for switching between masterservers...
So, either set False or True, I have lost about half the servers on my list... including Altfire and Beginner's...
Also when I look at my ini, I notice Gamespy, Fragaholic and DXMTL.EU are present...
may I post my ini in case it is necessary...sorry for trouble... Also I noticed some file in my system Folder which mentions dxalpha.com.... so I attach that too... it's also called "Deus Ex"...
Have I installed MMU160 wrongly somehow?
DeusEx.zip
Deus Ex.ini in Zipped Format.
Shadowrunner[FGS]
(3.66 KiB) Downloaded 2199 times
DeusEx-LOG.zip
Some kind of Log file which mentions MMU160
(2.7 KiB) Downloaded 2121 times
[FGS]ShadowRunner
Postby Alex » Mon Apr 02, 07 2:33 pm
Set bCombineMasterServers to True, and it should work, and I noticed that there are less servers in general. And about the dxalpha.com part, that piece of script checks if your current version of MMUI is up to date :)
Postby [FGS]ShadowRunner » Mon Apr 02, 07 3:26 pm
Thanks Alex
Yes more servers appear when US players start playing than during GMT daytime...
This is set TRUE
If I set false I see exactly the same thing...
The strange thing is, on the same day, ten minutes earlier with version 4.4 I could see over 20 servers and scrollbars...
I heard a player state that "STEAM's new release of DX may have something to do with some servers disappearing."
I was thinking since 144 Version was so wonderful for me, I could try it again? Sometimes everyone is on BEGINNERS server, it's a little frustrating...
May I say FXXK Deja and his "project"...
[FGS]ShadowRunner
Postby MainMan » Mon Apr 02, 07 4:14 pm
Here's version 140, the one I use. It doesn't check for updates, and everything works like a charm. :)
MMUserInterface140.zip
(35.42 KiB) Downloaded 1922 times
Postby Dae » Mon Apr 02, 07 4:23 pm
At the moment it seems that GameSpy masterserver is offline, therefore those who use bCombineServers=true may see only servers connected to dxmtl.eu.
I can't ping master0.gamespy.com either.
Postby [FGS]Majestic » Mon Apr 02, 07 8:51 pm
I can see all servers at the moment :)
[FGS]Majestic
Postby [FGS]ShadowRunner » Mon Apr 02, 07 9:06 pm
I already suspect that MainMan has the answer... thx dude I'm gonna try it now and let you guys know. Also Dae I think you are right.
Sanctuary - what version of MMU do you have?
EDIT: BINGO!!!! I just saw 24 Servers!!!! Version 4 works the best for me then...
Thx oh great [A]clan
[FGS]ShadowRunner
Postby Alex » Tue Apr 03, 07 7:26 am
ShadowRunner, there is no difference between the results of 160 and 140. I just tried them both, and both only showed servers that are on the FGS masterserver. Master0.GameSpy.com is offline. I have ping'ed it aswell, and got a packetloss of 100%.
You may use 140, I don't really care, but I advice to use 160, because it has parallel connections, thus making it faster. It is just slow right now, because one of the masterservers is down.
Postby ~M3GG4~ » Tue Apr 03, 07 4:41 pm
:( UserInterface dont work with alrighty game
<center> Image </center>
<center>Deus Ex Soldiers
~M3GG4~
Postby Alex » Tue Apr 03, 07 4:43 pm
What do you mean by that?
Postby Crusader » Tue Apr 03, 07 5:34 pm
U cant have alrighty and MMuser at same time. But i got a solution my friend. A Serverstarter.
Copy this into a .txt file, then change the file to .bat, then just click it to run a remote server, with alrighty game, then just change ur deusex.ini to the UserInterface, and u can still run ur dx server with alrightygame.
DeusEx.exe DXMP_RPGCity?Game=AlrightyGameV3.AlAdvTeam?-server?log=server.log
This code alone is enough to run a server from the .bat.
Change the gametype part if u want a Deathmatch, just check the alrighty readme for gametype codes. :D
Hope this little info helps, i know it works cus i am running it right now :lol:
Edit by [A]llan- Not everyone has MMImTyping. Thank god... ;)
Crusader
Postby Tonnochi » Wed Jun 27, 07 9:47 pm
This mod seemed great in the beginning. Long story short, tell me how to uninstall it.
Postby Kaiden » Sat Oct 06, 07 1:09 am
HOW DO I UN INSTALL THIS?
Postby Survive. » Sat Oct 06, 07 1:20 am
Do the installation process backwards? That is what I usual do anyways :?
Survive.
Postby Kaiden » Sat Oct 06, 07 1:24 am
But you just run an .exe, so I dunno what files/alterations it created/placed/made/altered/deleted/erased/changed/re-named/ate, etc.
Postby Allan » Sat Oct 06, 07 9:39 am
Provided you still have the readme for DXMTL, I recommend deleting/moving anything with MMUserInterface in its name, then follow the installation instructions for DXMTL again, subbing the default player class info for the MMUI ones.
Postby Alex » Sat Oct 06, 07 9:40 am
Allan wrote:Provided you still have the readme for DXMTL, I recommend deleting/moving anything with MMUserInterface in its name, then follow the installation instructions for DXMTL again, subbing the default player class info for the MMUI ones.
He's right ^
Postby Kaiden » Sun Oct 07, 07 12:34 am
But didn't it add stuff like EditPackges=MMUserInterface6.0 and stuff in the dx.ini?
Postby Alex » Sun Oct 07, 07 8:24 am
Nope.
Postby Shinobi » Tue Oct 16, 07 12:08 pm
Until this is needed again, if ever, methinks nobody should touch it.
No offence to Alex, and I mean that, it ain't personal, but MMUI was the most evil thing I ever added to Deus Ex!!
Aaaaaanyhoooooo - Can't remember why I posted here.
Postby {17}agentsmith » Wed Oct 17, 07 8:30 pm
am i the only person who appreciated the mod? :shock:
{17}agentsmith
Postby Kaiden » Wed Oct 17, 07 8:53 pm
I did, when it worked heh.
Postby Alex » Fri Nov 02, 07 8:28 pm
UserInterface 180 has been released! Download it now!
Postby Alex » Fri Nov 02, 07 8:45 pm
Already found the first bug. Nothing serious though. The mod self thinks it's still V1.7. Wont affect you in any way.
Postby Survive. » Fri Nov 02, 07 8:51 pm
Very nice :D
Favourites. Hmm sounds like a good add on :D
Survive.
Return to alpha laboratories
Users browsing this forum: No registered users and 46 guests
